Ricoh MP C4504 color registration issues
  • cinelli
    • Jun 2021
    • 2
    I have an MPC 4504 that fails when attempting colour registration. SP2111 C works fine for a course adjustment but fails on A or D. We have replaced the ITB and Cleaner, also the ID sensors. Ive also worked through all of the countermeasures listed in the service manual with no improvement. Now looking at replacing a possible laser unit, BCU or IOB. Has anybody else seen this before?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP C4504 color registration issues
    What sort of life are the drums and devs on? When you print out a test pattern does it look like any particular colour is out of registration more than the others?
    Hit it.
    • sandmanmac
      • 3981
      Many years ago there was a post from someone that I made note of, that I refer to as "Advanced Line position Adjustment".
      It was originally for really old machines like the MP C3500's, etc, but I used it several times through at least the '01 series colour units with success.
      Look for my post on this thread. While it didn't work in this case, it can't hurt to try.
      Ricoh MP C3300, info after Engine reset
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Why would you start looking at pwb's what's the pm lifes start there 1st what's the copy quality like
        Regards Mark
          because they don't think logically ....
            • 37491
            Did you replace the entire ITB assembly or just the belt? Ricoh has had problems in the past with belts slipping on the assembly.
            When you replaced the ID sensor was it a new assemble or did you take it from another machine. A new assembly comes with a sticker that has the values for SP3-333, SP3-334 and SP3-335. If those are not correct you will get errors.
            You still have not answered TonerMunkeh's question. Drums or development units that need to be replaced will cause procon errors. Under toned developers will causes errors as the ID sensor cannot read the patches clearly.
            • tavorh
              • Sep 2016
              • 25
              I have a similar problem, anyone have a solution or suggest?
              • sandmanmac
                • 3981
                Yes, Several.... immediately above!
                What have you even done/ tried?
                Perhaps the original poster has found a solution, but he's apparently to selfish to share it
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  This week I had this problem the order that fixed it for me was force line adjustment c then a in that order then colour registration adjustment worked
                  Regards Mark
                  • tavorh
                    • Sep 2016
                    • 25
                    I replaced the laser unit and ITB unit, also I did process: ''Ricoh MP C3300, info after Engine reset''
                      Did you input the settings from the new laser?
                      • emiliorsg
                        • Jul 2018
                        • 141
                        I had a similar problem with a MP C2503 and the failure was caused by the pcu bk.
                        • tavorh
                          • Sep 2016
                          • 25
                          Not yet, I also installed an old laser. The customer only prints in black, wich is ok for now.
