MP C8002 no image
  • digicor
    • Jul 2008
    • 1159
    MP C8002 no image
    MPC8002 has had the control board replaced with a good use working one from another machine, there is
    no Code, or image internal print or copy
    in service mode we do get the "Grid" from being in service mode but no image
    all memory has been cleared except "all" and " engine"
    all birth certificate settings are in the right places
    it has not been moved causing any laser mirrors to be sent askew
    anyone have any situation like this? or any suggestions?
    firmware is also up to date
    the eeprom is the same from the original machine
    thanks
  • tonerhead
    • Sep 2009
    • 582
    Re: MP C8002 no image
    You did not mention why you changed the controller. Might it be that the bicu is bad also? If you run process control, does it give an error then?
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
    • digicor
      • Jul 2008
      • 1159
      No it does not
      • digicor
        • Jul 2008
        • 1159
        machine had a 672-12 code
        • FrohnB
          • Jul 2017
          • 1919
          One of our techs has seen where the drawer unit doesn't close all the way and the grounding pin for the Paper Transfer unit wasn't making contact. Usually would give you an SC460 though.
          If you stop a job mid-print, does the image show up on the drums or ITB belt?
          I'm guessing there's a poor connection somewhere.
          Bad memory DIMM?
          Omertà
          • digicor
            • Jul 2008
            • 1159
            Bad memory DIMM?
            ill check that image on the itb/drums tomorrow and ill take a set of dimms
            Thanks for the suggestion
              • 37624
              That is normally a communication error from the controller to the control panel. If you know how to move through System SP blindly try to export the Logging Data SP 5992-004 to an SD card. You can then check the SC history to se if there was any other service code.
              What you describe "in service mode we do get the 'Grid' from being in service mode but no image" tells me that the display is functional just not getting the data from the engine. The "Grid" is generated by the Operation Panel loaded on the panel.
              Possible causes:
              1. Bad connection from the control panel to the IPU.
              2. Bad connection from the Controller to the IPU.
              3. Bad IPU board.
              4. Bad controller board
              • digicor
                • Jul 2008
                • 1159
                update not resolved
                all boards have been changed, memory dimms replaced,
                there is no image on the drums or ITB
                i downloaded nvram then ran memory all clear
                now it shows paper in d2 (fuser) where there is none, doh!!
                no jam before the memory all clear..
                .i realize this is a wacked situation for a machine, i have never encountered no image/no code..no harm no foul no shirt no shoes no problem...lol
                i have replaced the machine with a c6004 so now the mpc8002 is a corral reef candidate for ocean exploration
                but before we scarp it is there any other possibility causing this anyone can think of?
                and remember there is no code the machine thinks its working properly
                • digicor
                  • Jul 2008
                  • 1159
                  forgot to mention
                  re loaded NVram... no fuser jam .... oh and No Image either....hahha
                  its a boat anchor...
                  if anyone needs parts please let me know
                  thank you
                    • 37624
                    forgot to mention
                    thank you
                    Have you checked to see if the laser shield glass is covered with toner or dust? That would cause no image and would not generate a service call code. If the shield glass is missing or broken you could have toner haze throughout the entire laser unit
