SC681
  • Ricoh-ono
    • 339
    SC681
    Error SC681-xx
    I've run into this a few times on the '03 and '04 midsize color machines. I know there is a bulletin regarding the bottle lock spring but I've also found another cause for this error. Each chip on the toner bottle touches a board (PCB:TCB) at the back of the machine. I've found that when this error occurs the PCB:TCB is usually covered in toner. Specifically, the solder joints on the back of the harness connector face towards the bottle. I suspect the toner might be shorting out the connector. Usually, after I clean the board I will seal it with hot glue. I've not had any return for this error after the repair was made. I've attached photos of the PCB:TCB and the steps taken.
    Do what you can, with what you have, where you are. ~Theodore Roosevelt
    • 37557
    Re: SC681
    I have usually found that one or both of the contacts on the post is damaged.
    • mikadonovan
      • May 2008
      • 2931
      Re: SC681
      Thanks for this one. I am going to try the hot glue thing, as I have intermittent 681's on my equipment too. How involved is removing the little PCB from the machine for the mod?
      NEVER ASSUME ANYTHING
      • Ricoh-ono
        • 339
        Re: SC681
        It's not that difficult. Once you swing the controller box out of the way the toner bottle motor and PCB:TCB are right there. 2 screws for the motor, 2 screws for the board, and loosening the harnesses to get the motors out of the way.
        • mikadonovan
          • May 2008
          • 2931
          Re: SC681
          Ricoh states that outside RF interference is also a cause for this code. I bet that covering those solder joints with glue will also help out with that.
          • JDYAL
            • Sep 2008
            • 187
            Re: SC681
            Just had this problem. Damn good info. Thanks for the help.
            • Gift
              • Mar 2011
              • 2459
              Re: SC681
              Thanks for sharing!
              • mikadonovan
                • May 2008
                • 2931
                Re: SC681
                I tried the hot glue mod on a C4503 that was coding for all colors. It fixed all codes but the one for magenta, so it does work.
                • luca72
                  • Oct 2017
                  • 1791
                  Re: SC681
                  Originally posted by Ricoh-ono
                  Error SC681-xx
                  [ATTACH=CONFIG]49528[/ATTACH] [ATTACH=CONFIG]49529[/ATTACH] [ATTACH=CONFIG]49530[/ATTACH]
                  Grazie, if it happens to me, I'll try
                  "I'll be back"
                  • Ricoh-ono
                    • 339
                    Re: SC681
                    One thing I failed to mention in the original post is that I don't carry a hot glue gun. I found that a cigarette lighter and a glue stick work really well. It's compact and doesn't take any time to heat the end of the glue stick for use.
                      • 37557
                      Re: SC681
                      For those non smokers, a soldering iron also works. It also allows you to tack weld broken plastic parts to hold them in place while applying the hot glue.
                      • Cleber
                        • Jan 2016
                        • 7
                        Re: SC681
                        very good tip, I'm suffering with these codes here in Brazil!
