MPC307spf - Dead as a doorpost
  • Polarbear
    • Feb 2012
    • 1070
    Hi All
    I have an MPC307spf that is as dead as a doorpost.
    We replaced the AC/DC power supply as well as the AC detector board.
    Pressing the power button has no effect whatsoever. No fans/motors activity and no LED activity on the boards.
    Has anyone come across this before?
    I would appreciate your feedback.
    Press the GREEN button!!
  • copier tech
    • 8192
    Re: MPC307spf - Dead as a doorpost
    Originally posted by Polarbear
    Hi All
    Get your meter out should be pretty easy to check main voltage etc.
    Especially check the fuses on the boards you replaced maybe they blew as soon as you replaced the boards.
    • Mark Bbb
      • Jun 2012
      • 1662
      If it was caused by a piek current f.i. thunderstorm, it could very be that other boards are damaged too.
      In fact, here in Belgium, damage after f.i. a thunderstorm we describe the machine as "totally unreliable" when making up a cutlery for insurance.
      And selling a new machine is the (only) solution.
      • Polarbear
        • Feb 2012
        • 1070
        Hi Copier tech.
        Yes I did check low voltage and AC power supply fuses, as part of the fault finding, and all are good on both power supplies.
        • Polarbear
          • Feb 2012
          • 1070
          Hi Mark Bbb.
          Would love to get insurance involved, but I need to find proof of electrical damage (which so far is not forthcoming) as there is no black burn marks or parts that are blown of the board.
          • dave w
            • Jun 2015
            • 230
            Thunderstorm ?
            If you suspect that may be the cause then check the fax area as the tel line may have been hit, I have seen this some years ago.
            Good luck
            • Mark Bbb
              • Jun 2012
              • 1662
              Hi Mark Bbb.
              We always ask customer if there was a power failure recently.
              The last case we had was a road construction.
              The damage can go up to 6 months ago! Because the tinny components will have a tear which - due to temperature - will get bigger in time.
              But... it is hard to prove that a power failure of 6 months ago was the cause.
              Good luck!
              • Gift
                • Mar 2011
                • 2459
                Good luck!
                I wouldn't try anything without a parts donator - in know that the pricing for PCBs is very expensive so even little damage with more than 1 baord means that you can write this unit off and get a new one. Plus you'll never know if there are hidden issues waiting to occure some day later.
                • copier tech
                  • 8192
                  Hi Copier tech.
                  Are there any LEDs on the controller blinking etc?
                  • Polarbear
                    • Feb 2012
                    • 1070
                    None at all. no noise of fans/motors either.
                      • 37556
                      Hi Copier tech.
                      But did you take voltage readings on the PSU connectors or anywhere else in the machine?
                      • FrohnB
                        • Jul 2017
                        • 1919
                        Have you tested to see if the wall outlet is bad?
                        Is the copier power cord bad? Correct power cord?
                        Omertà
                        • copier tech
                          • 8192
                          Exactly the point I was trying to make.
                            • 37556
                            That is what I thought.
                            • Polarbear
                              • Feb 2012
                              • 1070
                              Re: MPC307spf - Dead as a doorpost - SOLVED
                              Hi all
                              just an update on the MPC 307 doorpost.
                              Replaced the complete controller and BICU cage this morning, and it started!
                              Swopped customer's NVRAMS and HDD over and it still worked!
                              So all is well in MPC307 land...
                              Thanks all for your ideas and input.
