printer activation on a 4G network
  • Mark Bbb
    • Jun 2012
    • 1662
    My thread of 'only modem printer installation"
    printer installation only on modem
    isn't cold yet, and now a customer had a data cable broken (digging work outside) and ask to do a printer installation of her mpc2051 via her i-phone.
    Thank you (again) for you input.
  • mojorolla
    The Wolf
    • 2583
    Re: printer activation on a 4G network
    There is a trick I learned long ago, and it can be a bit tricky to master.
    We all want to do right but our customers but sometimes, the best thing you can tell them is "no".
    • Debs1964
      • Oct 2010
      • 1687
      I have never had to do this, but I have attached a screenshot of the personal hotspot settings on my iPhone (with my password erased, obviously), it looks possible to me
      There are 10 types of people in this world, those who understand binary maths and those who don't
      • Mark Bbb
        • Jun 2012
        • 1662
        [ATTACH=CONFIG]49565[/ATTACH]
        Debbs, ok, if the printer has a wifi function. But this mpc2051 hasn't. It uses a T-link, so data is traveling over the electricity cables to the other end of the T-link (which is than connected to the router). But... that router is out of service now cause of the cable broken (for a few days). There are some wireless tools, i don't know a lot about them.
        • 8T2
          • Aug 2015
          • 257
          Originally posted by Mark Bbb
          Debbs, ok, if the printer has a wifi function. But this mpc2051 hasn't. It uses a T-link, so data is traveling over the electricity cables to the other end of the T-link (which is than connected to the router). But... that router is out of service now cause of the cable broken (for a few days). There are some wireless tools, i don't know a lot about that.
          If it's a WiFi router you could in theory just switch it to WiFi repeater mode/WiFi bridge mode and connect that to the iPhone hotspot for internet connection. Depending on router specs and if it supports extender mode obviously. Just a theory, never had to try something like that before.
          Sent from my WAS-LX1 using Tapatalk
          • Mark Bbb
            • Jun 2012
            • 1662
            It should go with a (damn forgotten the word) repeater(?).
            Flybox is it named here in Belgium and the provider is Orange, it has a SIM card in it.
            After installation that signal is than picked up by an i-phone.
            The printer is connected to that "repeater" (?) and so it should work.
            • 8T2
              • Aug 2015
              • 257
              The printer is connected to that repeater and so it should work.
              In theory yes. WiFi router as extender/repeater/bridge will connect to hotspot wirelessly and wired connection from router to printer.
              Remember to switch printer DHCP on and write down current network settings to reverse everything when their line gets fixed and don't need to use the hotspot anymore
              • jhalfhide
                • Apr 2015
                • 451
                Unfortunately iPhone tethering and hotspot software is specifically designed to ringfence each connection for security purposes. You can have a handful of people join the same iPhone and they will all get internet but no network communication will pass between the clients.
                You'd need to go out and buy a little router that supports tethering or client mode.
                Sent from my LYA-L09 using Tapatalk
                • 8T2
                  • Aug 2015
                  • 257
                  There goes my theory then.
                    • 37195
                    What is the distance between the buildings that where connected by the broken underground cable? If it is too far for a normal WiFi connection, there are companies that provide extended wireless connection. The construction company should be responsible for the cost.
                    Is the customer just wanting to print to the C2051 from her iPhone? If you can install a WiFi router connected to the C2051 she should be able to connect the iPhone to the WiFi. One of Ricoh's apps for iPhone should then allow printing to the C2051 by IP address.
                    • ginacornis
                      • Jul 2021
                      • 1
                      Hmm, I had a similar problem when I tried to connect Roku to WiFi . Roku did not perceive my internet distribution hotspot from the phone. I have tried different ways to solve this problem. I tried to diagnose the device through the Mobile Boost app, but it didn't help. I tried restarting the Roku and the phone, but it didn't help either. I contacted the Internet service provider, but they could not help me there. I bought a portable 4G modem using a SIM card and was able to solve my problem. It provides a good internet connection. Maybe this will help in your situation. It seems that such modems create a network that is an administrator. Maybe it's important for someone.
                      • copier tech
                        • 8130
                        What about simply running a USB cable to her PC/Laptop? that will get her printing temporarily.
