Just wanted to post that I had a mp305 that had a sc672-11 and it ended up not being a nand flash or a controller, but was in fact a bad fax option. If you get that code slide the fax option out and turn back on the copier and see if the code clears. If not try the nand flash then controller as last resort.
Ricoh MP305 SC672-11
