C6004 fax error
  • mikadonovan
    • May 2008
    • 2931
    C6004 fax error
    Hi, All. I keep getting a "unfortunately the fax function has stopped working" on a C6004. It seems to coincide with a paper tray being overloaded. The fax is not in use on this machine. An application clear gets rid of it, but it comes back. Is there a way to completely disable the fax on this machine? Thanks.
    NEVER ASSUME ANYTHING
    • 37490
    U remember having the same problem with the previous C6003 model at a customer with 5 of them. Can't remember what I did to correct it but it was related to the tandem tray.
    • copier tech
      • 8144
      Update the device & SOP firmware, this will update the fax card & resolve the issue. Or physically remove the fax card from the device.
      • Zeldaman
        • Mar 2011
        • 946
