ricoh mpc4501
  • alphablaster
    • Nov 2020
    • 32
    ricoh mpc4501
    Hello everyone !! I was wondering if anyone could help me with this : I have a ricoh mpc 4501 and I have blue letters instead of black, this is only on the copying mode either I put the original at the ADF or the glass(I have cleaned the optics). Any ideas of what that might be? Should I change the laser unit ? Thank you in advance !
  • COPIERMAN
    • Jun 2009
    • 561
    Re: ricoh mpc4501
    if printing is fine. Then i would said ccd in optics is problem. I have seen them with nothing on glass get a blue copy come out.
    • alphablaster
      • Nov 2020
      • 32
      Re: ricoh mpc4501
      ok, i will change the ccd and i will post the results. Thank you very much !
      • Debs1964
        • Oct 2010
        • 1693
        Re: ricoh mpc4501
        Try doing a memory clear on copier application only
        There are 10 types of people in this world, those who understand binary maths and those who don't
        • menosmola
          • Apr 2014
          • 95
          Re: ricoh mpc4501
          has something happened with the nv-ram of that machine? The machines come from the factory with exact values ​​for scanning, contrast, brightness, color saturation ... Look for the sheet with the factory default values ​​and compare them with those of the machine.
          Enviado desde mi Redmi Note 8 Pro mediante Tapatalk
            • 37642
            Re: ricoh mpc4501
            Are you copying in B/W mode or in Auto Color detect. It is not unusual for "Black" ink on paper to appear as dark blue under bright lighting like you get from the exposure lamp. In B/W mode the color PCDU are not used and the color transfer rollers in the ITB do not press the transfer belt against the color drums.
            IMHO, Auto Color detection invariably will cause trouble. Set default to B/W.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Re: ricoh mpc4501
              Reset the white balance "Book settings" in the Scanner SP settings back to the birth certificate.
              I assume that you're talking about a blue background all over the page?
              I've also seen this where everything comes out pink.
                • 37642
                Re: ricoh mpc4501
                His original post said blue letters instead of black. No blue background.
                • alphablaster
                  • Nov 2020
                  • 32
                  Re: ricoh mpc4501
                  I don't think so, the machine was working fine, this happened a day after we got it to the client i don't know what happened at the transport.
                  • alphablaster
                    • Nov 2020
                    • 32
                    Re: ricoh mpc4501
                    yes, it is on the b/w mode
                    • davel
                      • Oct 2011
                      • 1109
                      Re: ricoh mpc4501
                      During transport the scanner got bent, good luck.
                      • alphablaster
                        • Nov 2020
                        • 32
                        Re: ricoh mpc4501
                        Fortunately not ! It was the ccd
