Noise while scanning to email on DF
  • Babaknr
    • Jun 2020
    • 9
    Hi there,
    There is a noise on IM C4500 Document feeder (top feeder) while scanning to email with 200 or 300dpi not 400 dpi.
    Any ideas please!
  • dave w
    • Jun 2015
    • 230
    sounds like the 400 dpi is going through slower so less stress on something. in the pased I have found noise when manualy moving the rollers/ mech slowly but not when rotating them quickly. this may help you point to the area thats making the noise.
    • Babaknr
      • Jun 2020
      • 9
      Hi,
      I tested output check for roller exit drive which makes same sound and replaced the roller, but got no luck.
      • Gift
        • Mar 2011
        • 2459
        Back in the days a slippery feed belt could cause noise but I think that's not the case here if you can hear it when turning on the exit roller.
        Might be a bushing, idle roller, drive belt push roller but I can't really say what to check first, noise issues are rare with these DF types.
        • Babaknr
          • Jun 2020
          • 9
          Thanks for your idea, I will check a bushing. All DF belts and roller exit drive already replaced.
          • RicohBoomer
            • May 2022
            • 40
            On older machines I recall that the ADF would start "screaming" whenever the separation roller had degraded enough.
            Unsure if the same symptom happens on the IMC-series since we don't have that many old IMCs out there yet.
            • Babaknr
              • Jun 2020
              • 9
              Thanks, I will check it out again.
                • 37488
                I have encountered motors that make noise only when operated at one of their possible speeds, A two foot length of 1/4 inch copier tubing makes a nice stethoscope for pin pointing the exact source of a noise. One thing, I have had brand new motors be noisier that the original.
