ricoh mpc 3501 jam
  • alphablaster
    • Nov 2020
    • 32
    ricoh mpc 3501 jam
    Hello everyone !! I have a problem with a ricoh mpc3501, it appears to me paper jam in the fusing unit but there's no paper anywhere in the machine, although i changed the fusing unit but still the same... I'm thinking of it might be a sensor at the paper exit but I don't know which. Any ideas ? Thank you in regard!!
  • 8T2
    • Aug 2015
    • 257
    Re: ricoh mpc 3501 jam
    Where is it logging the jam on your SMC? Have you done input check yet?
    When you say there is no paper in machine does that mean the printed page exited and is laying in the exit tray?
    Sent from my WAS-LX1 using Tapatalk
    • alphablaster
      • Nov 2020
      • 32
      I did the input check everything seems ok, now i get sc-582, no there is no paper anywhere at the machine.
      • davel
        • Oct 2011
        • 1095
        Fix the SC582 first.
        • GIUBOSS
          • 1391
          jam code? sc582, why do you change the fuser with the machine blocked by jam? reinstall the old fuser and clear the jam first
