Pro8200 SC471-02
  • toddanderson
    • Dec 2005
    • 236
    Pro8200 SC471-02
    I am working with a pro8200 with a constant SC471-02 code
    I have replaced the ITB unit and the Hp centering sensor
    Transfer roller D1796108 and the Opposed roller D1796078
    Thank you for any help, much appreciated
    • 37491
    Re: Pro8200 SC471-02
    Are you trained on any Production model?
    Do you have the service manual for the Pro8200 and know how to use it? I rather doubt it. If you did you would not have touched the PTR. According to the Service Manual SC471-002 is Belt centering roller HP error. That has to d with the ITB assembly not the PTR.
    • toddanderson
      • Dec 2005
      • 236
      Your correct i replaced the ITB assembly and forgot to add I replaced the centering Hp sensor.
      I replaced the PTR earlier on a different issue.
