Ricoh IM C3000 + MAC
  • diable69BG
    • Jan 2021
    • 7
    [CQ] Ricoh IM C3000 + MAC
    hello everyone can we do rotating printing with a ricoh im c3000 and a mac?
    thank you
    if so how can this be done in the print driver?
  • 8T2
    • Aug 2015
    • 257
    Re: Ricoh IM C3000 + MAC
    Does the device have the optional PostScript unit installed?
    If yes, check in driver
    If no, chances are you can't because the generic PCL driver has almost no features.
    Sent from my WAS-LX1 using Tapatalk
    • diable69BG
      • Jan 2021
      • 7
      yes she has the postscript card + Drivers PS.
      and the finisher is a SH3080and the finisher is a SH3080
      • 8T2
        • Aug 2015
        • 257
        If the device has the PS installed and the Mac has a PS driver installed the option must be in driver somewhere. We are both talking about rotating sort though right?
        Also make sure you actually have 1 tray LEF and one tray SEF of same paper size and type for rotate sort
        • Brianneoe
          • May 2015
          • 322
          Make sure you have the Ricoh PPD for that machine on the MAC. Don't use the native driver that the MAC offers because it won't show all the options. There is a lot of good info here on the CTN site that will guide you on how to load and configure the PPD correctly. If it can be done on a PC it can be done on a MAC.
          Good luck
          • rthonpm
            • Aug 2007
            • 2859
            Is the finisher listed in the device options of the PostScript driver on the Mac?
            Most problems with finishing I see come from the correct options not being added in the driver settings so as far as the driver is concerned there's no finisher or high capacity tray, etc.
            Sent from my BlackBerry using Tapatalk
