Help ! No duplex option in Ricoh MP 2014AD 247-27
  • oknic
    • Dec 2023
    • 23
    I have bought a used ricoh 2014AD (247-27 model, 42k clicks) with adf and duplex unit and all
    but i failed to make it print in duplex, nor the option to make duplex copy is present in the system menus
    even though i tried to make a duplex print from the driver but it always prints in simplex
    Is it a firmware issue or what? if yes can someone provide me with the firmware files !?
    if not what could be the problem ?
    i really appreciate your help
    thank you
  • luca72
    • Oct 2017
    • 1791
    Boh?...if not work also in Copy, try to format/replace the hdd (sp5-832)
    "I'll be back"
    • oknic
      • Dec 2023
      • 23
      I dont think that MP 2014AD has an HDD
        • 37556
        It doesn't but not needed for duplex.
        thank you
        Two things that will prevent you from being able to duplex.
        1. Paper type is set for Thick 2 or Thick 2. The turn at the bottom of the duplex unit is too tight.
        2. Duplex is disabled(Apply Duplex not Enabled).
        Both settings are in User Tools - System Settings - Tray Paper Settings.
        • oknic
          • Dec 2023
          • 23
          I put the machine on plain paper 2 none changes
          Also I couldn't find duplex setting on the machine system menus
          Any further help please
          • oknic
            • Dec 2023
            • 23
            20240526_111315.jpgimage widget
            The machine has the adf, the correct model number, all the optional clutches (reverse and duplex clutches and others)
            Where is the probelm
            Maybe a wrong firmware !? It onlay says 2014 in web interface shouldn't it say 2014AD !!!??
              • 37556
              That model line had 3 models 2014, 2014A and 2014AD. Only the 2014A and the 2014AD supported duplex. What does it show when you print the counter sheet? It could be firmware.
              • oknic
                • Dec 2023
                • 23
                Here it is ..
                • Polo-022
                  • Sep 2007
                  • 486
                  Duplex mode can be selected by pressing the Right Arrow button which is the entrance to Copy Mode.
                  Firmware seems to be the very first , but it has nothing to do with Duplex abilities!
                  • oknic
                    • Dec 2023
                    • 23
                    I tried it there is no duplex
                    And when i checked YouTube it should be more options in combine menu but this is all i got 20240526_200416.jpg
                    • Polo-022
                      • Sep 2007
                      • 486
                      Well, if you download the User Manual, read carefully pages 139, 140 how to enable or disable Duplex Mode. Right Scroll key is the magic key for you. Good Luck.
                      • oknic
                        • Dec 2023
                        • 23
                        Well you missed the point !
                        There is no other options like in the manual pages 86 and 139 etc
                        When i press the key i pnly get combine 2 originals or 4 originals no other option even though my machine is the 2014ad which i supposed yo have the all the duplex options like in page 86 and 139 etc
                        • Polo-022
                          • Sep 2007
                          • 486
                          ...shot in the dark...!! Thanks!
                            • 37556
                            What manual are you looking at, the service manual? You need to be looking at the Operating Instruction Manual. I just downloaded it and Duplex/Combine starts on page 139 and continues on page 140. The next option below the 3 that are showing in your picture is 2S->1S(NoComb) which is Duplex you have to press the DOWN Scroll arrow until it is highlighted. FYI, the SCROLL ARROWS are just to your right of the display. You can see the LEFT Arrow in your picture.
                              • 37556
                              I swear I am about to stop helping end users.
