cannot log in web image monitor ricoh mp301
  • Mark Bbb
    • Jun 2012
    • 1662
    #16
    Re: cannot log in web image monitor ricoh mp301
    Originally posted by alphablaster
    192.168.1.249
    I didn't put this ip, someone else did it and after this cause they brought it to me
    is this the right ip address or not?
    Yes or no?
    • alphablaster
      • Nov 2020
      • 32
      #17
      Yes or no?
      What do you mean the right ip? Right ip for what ?
      They brought it to me with this ip and it doesn't let me change it
      • davel
        • Oct 2011
        • 1094
        #18
        Is this the IP address that you type into your browser?
        • Mark Bbb
          • Jun 2012
          • 1662
          #19
          i give up now.
          • alphablaster
            • Nov 2020
            • 32
            #20
            Of course it is, i mean who should expect to reach WIM whithout typing the exact ip, this is self-evident
            • COPIERMAN
              • Jun 2009
              • 559
              #21
              ok you have to go into special service mode not the normal one. then 5-846 46 execute . turn off copier and back on now will ask to reset both passwords.
              • alphablaster
                • Nov 2020
                • 32
                #22
                At first thank you, second if you know could you please tell how to go to this special service mode ? if you mean the c143cc and do the 5-846-46, i've done that.
                  • 37324
                  #23
                  I cannot even reach the WIM, printing and scanning works, it is connected with lan cable, windows installed and yes tried firefox too but I can't reach WIM either
                  That usually means the a device certificate has been created. See my previous reply.
                  192.168.1.249
                  Is that the IP address used for printing? If so, then it is the correct address. If not, then it is the wrong address.
                  • keithxxiii
                    Just a tech
                    • Nov 2014
                    • 468
                    #24
                    If all network settings are correct, and you are able to ping the IP address, then try downgrading the network security level to "0"
                    Aye! Cut the crap
