IMC2000 (Magenta)
  • lhmy
    • Oct 2023
    • 33
    IMC2000 (Magenta)
    I have one IMC2000 with magenta issue
    have change the PCDU but the problem only solve for only 2 weeks and then come back again.
    have tried also changing the itb but stil the same
    The issue is that on the attached file (at printer parts there got magenta colour,supposed to be white)
    • 37491
    Are you sure that you didn't send the original twice because I am not seeing a difference other than what appears to be an edge shadow below the bottom of the document. If that is what you are having trouble with, it is more likely to be optical. Check for magenta toner on the mirrors.
    • Popolopo
      • May 2023
      • 134
      DId the magenta drum got line like the print? Did set 3-701 when change new PDCU?
      • lhmy
        • Oct 2023
        • 33
        the circle one is where the magenta is when it supposed to be white
        ive cleanup the mirror after changing the pcdu
        • lhmy
          • Oct 2023
          • 33
          no line on the magenta drum sir
          yes i did the 3701 and also 2005 sp
            • 37491
            Is that a copy or a print? If it is a copy, try scanning it to a folder and see if you get the same thing.
            • Popolopo
              • May 2023
              • 134
              then, i guess just need to do calibration at maintance there
              • lhmy
                • Oct 2023
                • 33
                its a print from pc and also did print from usb using the same file
                the reddish magenta is still there
                • lhmy
                  • Oct 2023
                  • 33
                  have done calibration and also registration but the issue remains
                  • Popolopo
                    • May 2023
                    • 134
                    only when printing? on copy also same.
                    if only printing, maybe driver. can try update the driver
                    • davel
                      • Oct 2011
                      • 1104
                      looks like reflection from the red carpet.
                      • sandmanmac
                        • 3981
                        Upload a proper test page from SP mode. One can't properly diagnose issues from random colour prints
                        • lhmy
                          • Oct 2023
                          • 33
                          using the latest one from ricoh web
                          PCL 6 Ver.1.56.0.0
                          • lhmy
                            • Oct 2023
                            • 33
                            on the original PDF its white and not red
                            • lhmy
                              • Oct 2023
                              • 33
                              test page
