Toner Density Ricoh 2503
  • Pixtech Frameworks
    • May 2020
    • 238
    Hi All,
    Is there any sp adjustment to reduce black toner density on Ricoh mpc2503 or any sp to reduce VT on OPC??
    Thanks.
  • davel
    • Oct 2011
    • 1107
    Re: Toner Density Ricoh 2503
    Follow PM schedule and use genuine parts.
    • MIKON
      • Jul 2015
      • 188
      I have seen after market toner cause problems on this model......
        • May 2020
        • 238
        It's an OEM toner. I still don't know why the black density its too dark.
          • May 2020
          • 238
          All parts are genuine OEM parts. I know there's an sp settings to be done, but I've forgotten. I'll try to remember.
          • davel
            • Oct 2011
            • 1107
              • 37544
              The problem is you do not think the problem all the way through. Any SP change you make to reduce, or increase, the density of the K toner will result in less toner being put on the drum. Less toner on the drum will result in less toner on the ITB. That will result in the ID patch being lighter, or darker, and Process Control will reverse your adjustment.
                • May 2020
                • 238
                I remembered I countered same situation and there's and sp 3xxx, but can't remember anymore.
                  • 37544
                  At least one of the critical SP settings that I used to change in previous models does not exist on the MP CXX03 series.
                  • copier tech
                    • 8184
                    Hi All,
                    Thanks.
                    Carry out a PM replace the K PCU & Dev if over life.
                    Update the firmware & run ACC.
                    This will most likely resolve any print quality issues you have.
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      Counters?
                      Did you fixed some problem before it started?
                      Since when did this happen, and what happened just before that?
