smb client check Ricoh
  • aviso66
    • Dec 2012
    • 202
    [Misc] smb client check Ricoh
    hi
    i just want to clarify if i go to telnet and check the smb version using the smb client auth.
    It has 0, 1 ,2.
    if it's 0 means it only supports smb version 1 and if the client auth 1 means it can support smb version 2 right?
    thanks
    so if the client auth can goes up to 2. does it mean it can support smb 3?
  • PrintWhisperer
    • Feb 2018
    • 453
    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
    • aviso66
      • Dec 2012
      • 202
      Re: smb client check Ricoh
      so only can use wireshark to findout the machine smb version?
      • PrintWhisperer
        • Feb 2018
        • 453
        If you want a definite answer in the easiest manner, yes. Obtaining the capture is easy, reading it takes practice. For this you don't even need a network TAP tool.
        Download free wireshark and install it on your laptop, or if available on the computer to which the customer scans.
        If laptop, give it an IP address compatible with the MFP and connect them with a network cable.
        Run Wireshark and select 'Ethernet Adapter' for capture.
        Initiate scan to folder operation directed to your laptop shared folder. It does not need to succeed with username and password, just to see the share and try to connect.
        (The version negotiation happens before the Uname/pwd check)
        Once it fails, stop the capture.
        If you can post that file I'll read it for you or PM me for instructions to DIY
          • 36831
          No! You can use Web Image Monitor: Device Management - Configuration - SMB - Advanced Settings
