Error code sc689-00
  • M.wagih
    • Mar 2024
    • 19
    Error code sc689-00
    Ricoh pro c5200 how to fix error sc689
    I hope you can help
  • tonerhead
    • Sep 2009
    • 582
    If you are a trained tech, you should know how to troubleshoot this one. Unfortunately there is not a "quick fix" other than trying SP5810 reset for fuser and reseating connectors, hoping for the best. Check the temp fuses, thermistors, etc. Otherwise it could be the IH assy, the IOB, or wiring. If the customer has a "tcru" second fuser, try that and do the fuser reset.
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
    • M.wagih
      • Mar 2024
      • 19
      Ok, I will do that, and then tell you the result, but I just want to ask you about a little thing: where is this located IH assy, the IOB,, and can you provide me with pictures of it?
        • 37515
        The service manual has all of that.
