Ricoh MP 1900
  • ecoworld
    • 15
    [Misc] Ricoh MP 1900
    Hi
    I am having an issue with a Ricoh MP1900 machine. Initially it used to power on and display SC542 and switch off by itself. As the code refers to the fuser, I removed the fuser and checked the lamps are OK, removed the thermistors and cleaned it for toner deposits. After i put it back, it no longer powers on, no display , the power supply just makes a click noise, I presume for the relay and then dies.
    I swapped with another fuser and the problem remains the same.
    Any suggestions.
    Thankks
  • Polo-022
    • Sep 2007
    • 484
    Re: Ricoh MP 1900
    Remove the fuser unit, check both thermistors for a short circuit to ground/chassis, then switch on.
    If you see again the SC-5XX message, lucky you, if not, check power supply or a DC board...
    • KeviM
      • Oct 2019
      • 324
      Re: Ricoh MP 1900
      Hi
      Like the previous tech mentioned if you swapped the fuser unit and you sure that the unit is working, then you need to look at the power supply unit. Alternatively... This is a long shot, try swapping the controller unit.
        Re: Ricoh MP 1900
        Originally posted by ecoworld
        Hi
        Any suggestions.
        Thankks
        Did you clear the error in service mode after swapping the fuser?
        • davel
          • Oct 2011
          • 1104
          Re: Ricoh MP 1900
          • TonerMunkeh
            Professional Moron
            • 3865
            Re: Ricoh MP 1900
            The more alarming this is the OP said the machine switched on, displayed the SC, then switched off by itself?
            Never seen a Kir do that.
            Hit it.
              • 37484
              Re: Ricoh MP 1900
              I have had shorted dc motors, solenoids and clutches take down the 24V power supply during engine initialization.
