Ricoh IM C3500 Dead
  • Spud
    • Aug 2021
    • 5
    Ricoh IM C3500 Dead
    Evening, i have a blown FU102 on the AC board. Replaced fuse and once again blown.
    Im pretty sure it is the DC PSU taking it down.
    Can anyone please provide part numbers for both boards.
    Cheers
  • guitar9199
    • Sep 2016
    • 1100
    Re: Ricoh IM C3500 Dead
    Cheers
    AZ240323 (NA/TWN)AC POWER SUPPLY PCB8)
    D0BQ5184 (NA/TWN):AC CONTROL BOARD PCB9)
    Hope this helps!
    • Spud
      • Aug 2021
      • 5
      Great, thank you. Are you aware of any problems with these boards? Just popped out of the blue!
      • dalewb74
        • Feb 2018
        • 1150
        good electrical outlet? is it plugged into anything besides the outlet?
        • Spud
          • Aug 2021
          • 5
          Good clean supply.
          Been in situ for 2 years and has not missed a beat!
          • guitar9199
            • Sep 2016
            • 1100
            Good idea to get yourself a circuit tester, and look for excess load, line voltage drop, etc. If there's other appliances on the same circuit, that can cause issues as well.
            I didn't see anything about any fuse problems on the Ricoh TSRC, but there were a couple of other issues that a firmware update addresses.
            Good luck!
              • 37478
              Hope this helps!
              Be aware that those numbers are for North America and Taiwan, not the UK. If you are not 120V 60 HZ they may not work properly.
              • Gift
                • Mar 2011
                • 2459
                perhaps for a few millisecs
                I usually try and unplug everything fuser related before installing a new fuse.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Cheers
                  There's a fault with these boards you will need to both pwbs
                  Regards Mark
                  • Batman1976
                    • Jun 2016
                    • 91
                    Known issue.
                    New boards have been modified to stop fuse blowing, must be replaced a s a pair.
                    Batman1976
