mpc4503 gear drive on right door.
  • fshead
    • 2376
    greetings
    As I waited for a transport guide to arrive I went back to account to change the top transort swing plate to find customer
    broke the gear unit on the top of the right side door.
    They broke it from the frame and lost one metal shaft.
    Is this only needed for duplex?
    I figure i will have to drill and tap the old shaft to reconnect.
  • mikadonovan
    • May 2008
    • 2931
    Re: mpc4503 gear drive on right door.
    It looks like it is just for DX. I would also try to refix it somehow. It may not be too bad, it looks like it is attached to the metal framework instead of something plastic.
    NEVER ASSUME ANYTHING
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Originally posted by fshead
      greetings
      Had a couple of times you need to replace the side frame
      D1494631 SIDE PLATE:REAR:
      Regards Mark
        • 37529
        greetings
        What metal shaft is missing? What I do not see is the timing belt that is supposed to be around the white gear/pulley, the spacer washer that should be between swivel bracket and the frame and the nylon e-clip that goes on the that goes on the inside of the frame to hold everything in place. If instead the shaft was press riveted to the frame, you will need to replace the side frame or you will never get the right tension on the belt.
        • fshead
          • 2376
          you are right just the spring is missing and belt is on the door.
          i am going to drill it out and tap it and se a small screw to attach.
          thanks all
          • fshead
            • 2376
            call CAME BACK with jamming so i swapped a mpc2503 right side door and ran 1,000 copies for the account to test
            it is ok.
            so far so good..
            the account told they never use duplex..............
