imc3000 offset (ghost image) - sometimes
  • Mark Bbb
    • Jun 2012
    • 1662
    Hoi,
    Twice in a week and once in a print order... (dixit customer)
    Already upgradet firmware in july '21.
    Machine has 26K total counter.
    Is there an RTB?
    Thanks for your help.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: imc3000 offset (ghost image) - sometimes
    How often does it do the ghosting? Are they printing on non-standard media? Have you tried setting the tray to middle thick?
    Hit it.
    • Mark Bbb
      • Jun 2012
      • 1662
      T.M.: as i wrote before, it happens twice - or so - every week, could then be once in a multi print out.
      No, i won't set it to middel thick, that might be a solution but sleeve will worn (much) quicker.
      Ricoh must come with a solution (if the fault is in the software), no?
      Do you have access to Octopussy? Is there an RTB?
      • Zaxxon
        • 608
        Please start you post with brand, model, problem.
        • Mark Bbb
          • Jun 2012
          • 1662
          I will check cl unit
          • Mark Bbb
            • Jun 2012
            • 1662
            ITB Cl unit is ok, it is not blocked with toner.
            Firmware version = 2.28 (latest?).
            All fusing related SP's are on default.
            Customer says machine has this problem from installation on...
            I think this is a matter of firmware.
            Has someone meanwhile a proper suggestion?
            Thanks.
            • anothertech
              • 1757
              Thanks.
              Firmware is old, current is 4.59
              Turn on auto firmware update SP 5886-111
              • Mark Bbb
                • Jun 2012
                • 1662
                I've done the update, no good.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Originally posted by Zaxxon
                  Had similar on MP C4503 it was separation issue from one of the paper trays, so every now and then they reached this tray they got offset. Users didnโ€™t notice the extra sheet of blank paper.
                  I do not understand what you mean;
                  where is this second blank page located?
                  You mean that these 2 pages come together, as sticking to each other?
                  The distance between the original and the ghost is 37 inch.
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    Seems that the letterhead is the issue.
                    We have put this tray on medium thick and it seems that this setting the problem has solved...
                    Thank you for your inspiring help.
                    • Gift
                      • Mar 2011
                      • 2448
                      That good old "medium thick" trick - Either that or bumping the temps via SP for ~5deg celsius should to the trick
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        No, it did not solved this problem.
                        Yesterday there was (only) one printout (b&w) with ghost image...
                        The time between the above edited post (last week) and now it was ok.
                        • Gift
                          • Mar 2011
                          • 2448
                          It's still just happening with the letterhead paper?
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            The ghost image was on a normal 80 gr paper.
                            But because this machine is located in a separated room and the users are located at different locations in a big office my contact don't know if the previous print was on letterhead.
