Ricoh MP 2553 rebooting
  • ReproKev
    • 273
    FYI - I'm a Canon tech that only occasionally works on other models, so I'm not intimately familiar with the Ricoh sp modes and have never done a firmware update on a Ricoh.
    New customer calls me with a Ricoh MP 2553 stating that it reboots frequently when printing to it. I get there and test it to find that it also reboots when copying off the glass, and printing an internal counter page. As soon as the motors start moving, but before any paper gets fed, the machine reboots. Not every time, but about 10-20% of the time.
    Machine only has 34k on it and looks almost new.
    I checked sp7403 SC history and there were no codes listed.
    Wasn't sure what else to check, so I told them I would do some research and get back to them.
    To me, it seems like either firmware, memory, or hard drive is failing.
    I also noticed a message in the lower left of the screen - " Updating @remote certificate" not sure if that's related.
    Is this a common problem? Any troubleshooting tips on this model to narrow down the issue?
    • 37052
    Re: Ricoh MP 2553 rebooting
    Sounds like SC Auto Reboot SP 5875-001 on. Change the setting to 1 and it should display the Service Code instead of rebooting.
      • 37052
      [ATTACH=CONFIG]50036[/ATTACH]
      Very common problem when an end user cancels their service contract with the dealer or branch that installed @remote. The dealer deletes the machine from the @remote server in Japan. I don't know if it would be causing your error problem but it will create a lot of unneeded out going network traffic. Try clearing the @remote settings with SP 5816-209 Install Clear.
      • ReproKev
        • 273
        Thanks. I'll give that a try tomorrow as well as clearing the remote settings.
        • ReproKev
          • 273
          • anothertech
            • 1757
            Go in to service mode IO section, run the motors one at a time to see if if reboots of see if the motor won't run.
            • copyaction
              • Oct 2007
              • 985
              I would still want to try the HDD just to rule it out.
                • 37052
                Check the total for SP 7504-001. That is the total for Jams detected at power on. It includes false jams causes when the machines thinks a door has been opened and closed. For print jobs the job restarts from the beginning. If SP 7504-001 is high, you may have a bad door/cover switch. If you have a finished attached it most likely is one of the push buttons switches for the jam covers on the bridge unit.
                • DRichard
                  • May 2008
                  • 482
                  I like this suggestion.
                  My additional 2 cents just for thought, we have all seen flaky power supplies or inconsistent power at the outlets cause weird symptoms. I might look into what else is on that circuit or if they had severe thunderstorms about the time this began. Good luck.
                  "Enjoy every sandwich."
                  -- Warren Zevon
                  • tsbservice
                    Field tech
                    • 7941
                    +1 on this. I will concentrate on what is kicking on when reboot is due.
                    • MIKON
                      • Jul 2015
                      • 186
                      If it is connected to a esp line filter and the voltage drops below the set threshold the filter will turn off.Not saying this is your problem just something to check.
                      • anothertech
                        • 1757
                        1+ I've seen the ESP line filter cause that more that once,
                          • 37052
                          But wouldn't it cause it to shut off, not reboot? We already know that changing SC Auto Reboot corrected part of the problem.
                          • MIKON
                            • Jul 2015
                            • 186
                            Yes it shuts off power but turns back on after voltage rises over the threshold.....
                            • Dan G
                              • Nov 2014
                              • 56
                              i tend to agree not a firmware isue. either poer swith is faulty or sure protector is flickering off/on when under load? bypass surge
