Will the IMC series PCDU fit in the MP Cxx03 Series
  • copier tech
    • 8220
    [Misc] Will the IMC series PCDU fit in the MP Cxx03 Series
    As we know the IMC PCDU are considerably cheaper than the MPC so I wondered if anyone has successfully modified them to fit if so what is involved.
  • Gift
    • Mar 2011
    • 2459
    Re: Will the IMC series PCDU fit in the MP Cxx03 Series
    Not yet but it sounds like an interesting project for next week
    I was able to convert SPC840 PCUs for MPC3004 - can't recall the exact steps but it was pretty self explaining.
    • copier tech
      • 8220
      Let me know how you get on.
      I had this guide for the SPC to MPC PCDU conversion.
      Printer Version mpc3003- Installation Procedure.pdf
      • DP1
        • May 2016
        • 7
        Good Afternoon,
        Yes
        you can Fit Printer version IMC PCDU in to MP C 003/004 series.
        As you mention installation procedure in PDF,
        - Remove TD sensor with cable from old unit and Transfer to Printer version.
        - Remove TD sensor cover from Old unit and Transfer to printer version.
        - Now you needed remove gear and plastic from printer version Dev unit.
        - Must keep printer version black Rear cover to go back in new unit.
        - With player cutter make big hole on old plastic front cover. Also make small hole for screw to go in.
        - Install Printer version PCDU in to Machine.
        - Perform normal PCDU installation procedure with ACC.
        - NOTE: careful when putting back TD sensor to new Developer Unit. Make sure it stick properly.
        Thank you.
