IMC3500
  • GeorgeBest
    • Jul 2009
    • 525
    IMC3500
    HI,
    Got an IMC3500, when I try to put in data for example in adress book using the display I get no keyboard for entering the data . .
    When I tap the field there's no keyboard
    someone a clue ?
    thanks in advance
  • copier tech
    • 8133
    Re: IMC3500
    Originally posted by GeorgeBest
    HI,
    someone a clue ?
    thanks in advance
    Try a restart wait for the machine to fully come to ready.
    Also check the keypad is enabled.
    Changing the Keyboard Type and Settings | User Guide | IM C2000, IM C2500, IM C3000, IM C3500, IM C4500, IM C5500, IM C6000
    • GeorgeBest
      • Jul 2009
      • 525
      Re: IMC3500
      this is about changing the keyboard layout or style, problem is that there is no keypad popping up . . . .
      • Gift
        • Mar 2011
        • 2459
        Re: IMC3500
        HI,
        someone a clue ?
        thanks in advance
        Haven't heard about this issue so far, I'd probably check the firmware or perform a reset for the panel settings to factory default.
        • copier tech
          • 8133
          Re: IMC3500
          Yes, but if you change they layout etc & reboot you may find it will re-appear.
          • GeorgeBest
            • Jul 2009
            • 525
            Re: IMC3500
            keyboard display was disabled. (hardware)
            Now it works . .
            Thnx for responce
