Ricoh Counter E-mail not working
  • hydra920
    • Sep 2024
    • 1
    Machine : MPC 6003 ,IM C3010
    Firmware updated to latest version
    SP Mode(Factory)
    5-866 CounterE-mail setting all done
    Smtp is correct
    And Send Test …..OK
    But still haven’t received the automatic reply email ??
    What should i pay attention to?
    thank all
    • 37047
    NRS is a subset of @Remote. Has your dealership signed up for @Remote and done all the install steps required to use @Remote. If all you are wanting is for the counter to be emailed to you, that is a widget that can be installed on the SOP. With the 03s it coud be installed with the Smart Operation Panel Designer Tool. Check with Ricoh to see if it is still available.
    • monstercopier
      • Jun 2019
      • 50
      If send test is OK i would suggest checking your SPAM folder or try a different email address.
      my usual hiccup is the send test fails. But, since that was ok its gotta be somewhere.
      • Saturn
        • Nov 2023
        • 170
        I have made these settings on our MP C3003 and it works without any problems.
        The prerequisite is that Scan to Mail works.
        Set SP5-866-110 to “1” to enable Device Counter E-Mail Function.
        In SP5-866-114, specify the date to e-mail the counter
        value.
        Notification date
        0 Every day
        1 to 31 On specified date
        In SP5-866-115, specify the time to e-mail the counter
        value.
        Notification time
        Value
        00:00
        0
        09:48
        948
        23:59
        2359
        Using SP5-866-121 to 123, enter the destination e-mail addresses.
        SP5-866-121 for To address
        SP5-866-122 for CC address
        SP5-866-123 for BCC address
        I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
