SP MODE
  • lhmy
    • Oct 2023
    • 32
    SP MODE
    Hi guys, is there any SP mode where I can see the TCR level for each DEV
    If there is,what are the suitable value for each one
    Thank you
  • GIUBOSS
    • 1385
    Let's get off to a bad start mate... first of all the model of the box, among other things there is a birth certificate on which you can find the values ​recorded at the factory which is not the same for everyone. What you say I think is about the Drum section.
      • 37048
      Yes there is and if you were a trained Ricoh technician you would already know the answer.
      • ShafaqatBlogger
        • Feb 2024
        • 7
        In SP mode, you may can see TCR levels for each device, where lower values are generally better for performance
        • lhmy
          • Oct 2023
          • 32
          Yes Im not a trained RICOH tech and im here to ask to be a better tech sir and i think thats why this page is created then
          • lhmy
            • Oct 2023
            • 32
            if you could message me for the SP mode
            thank you sir
              • 37048
              thank you sir
              Request a service manual for what ever model you are working on. There is a for for requesting manuals. If you submit a proper request, someone might send you a copy for free.
