SP mode access on an IMC 530FB
  • mikadonovan
    • May 2008
    • 2931
    The UI is different on this model. This is probably a stupid question, but how do I access SP mode on ans IMC 530 FB?
    NEVER ASSUME ANYTHING
  • sandmanmac
    • 3981
    Hey Mika.
    I've not seen any of this model yet, but what do you mean by the UI is different? Just the icons, apps, etc?
    I'm personally not aware of the SP access procedure being any different on any of IMC series.
    Is it a keypad you're having trouble bringing up in order to access SP mode? Do you know the process of pressing the microswitch 3 under the cover on the side of the SOP, and check status button simultaneously to bring up a keypad?
    • mikadonovan
      • May 2008
      • 2931
      Thanks, Sandy. I usually just bring up the copier app with the keypad to the right. I spent part of the afternoon looking for the classic apps to install to no avail. Take care and thank you. Should be good in the morning!
      • sandmanmac
        • 3981
        I had a feeling that might be the case. Happy I could shed some light for you
          • 37488
          If it is a printer only model. it might not have any functions that require a number pad
          • sandmanmac
            • 3981
            It's a colour mfp
            • copyboy99
              • Jan 2020
              • 24
              on this model SOP EX3 button is on the Right side, hidden in small cover, use EX3 and Check Status to get the Number pad. No Classic apps on this model.
              • mikadonovan
                • May 2008
                • 2931
                I got it sorted out. Thanks for the responses.
