Hey guys, whats causing white spots in red fill areas? Old ricoh
  • Patrick T
    • May 2023
    • 23
    Low milage old ricoh cl7200 started leaving random spots in red fill areas. Guesses why?
  • JR2ALTA
    • Feb 2010
    • 2033
    I suspect it's not the Cyan, Yellow or black consumables...what's left?
      • 37652
      For that printer the recommended replacement of all 4 of the PCUs is 30K. If it has been more than a year since they were last replaced, replace them anyway. The development units may also need to be replaced. Your biggest problem is going to be finding the maintenance kits. Precision Roller does not have them. e-Bay and Amazon might.
      Personally I would get a much newer printer.
      • Patrick T
        • May 2023
        • 23
        The machine was uncrated for first time last year. Ran maybe 1k. I do have doubles of everything. I was just hoping maybe someone could suggest which consumable would cause these odd marks before i dig in. I do plan on upgrading in the future. Thanks
          • 37652
          The copier version of that model was introduced in January 2004. It was replaced by the next model in June 2005. I already told you what would cause it. Parts and service support have long since expired.
          • Patrick T
            • May 2023
            • 23
            Thanks slim, excellent advice as usual. Do you think I should shake up the toner while im at it, or pop in replacement?
            • davel
              • Oct 2011
              • 1109
              If it’s repeating at drum circumference replace M PCU.
              • Saturn
                • Nov 2023
                • 173
                Make sure you only use original Ricoh parts and toners.
                I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
                • davel
                  • Oct 2011
                  • 1109
                  But you can not get them.
                  • anothertech
                    • 1771
                    It looks like developer clumps, try doing toner refresh.
                    • Patrick T
                      • May 2023
                      • 23
                      Im sorry, how so? A function on machine or replace?
                        • 37652
                        I did some checking and the Maintenance Kit Type 7200 7300B, set of 3 color PCUs is still available.
                        • Leoculus
                          • Jul 2024
                          • 62
                          if it is random and not repeating on the page most likely there are clumps of toner in the developer. you could try a new magenta dev unit but likely the toner being supplied from the bottle is where the clumps are coming from. if so you would want to clean the whole toner add system for magenta and try a new bottle. then run full dot test patterns to bleed the existing toner from the dev unit. but with the age of the machine you might find it hard to find a bottle that hasnt been sitting for 15+years on a shelf.
                          • Patrick T
                            • May 2023
                            • 23
                            Well bummer. I'll do what i can. How the heck do you dispose of these monstrosities?
                              • 37652
                              Any salvage yard. They will strip it for any recyclable plastic, metal and glass.
