noise from fusing on MPC4000-5000
  • largo
    • 30
    Customers complaining from noise from fusing
    they told us nothing can be done about this
    anyone has a solution?
    Greetz
    greetz
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    The newer MPC4000/5000 models use a motor to apply and decrease the fusing pressure (it's to help prevent flat spots occuring).
    Unfortunately it can sound fairly loud and clicky but that is the norm unless they bring out a mod.
    • largo
      • 30
      ok thanks cipher
      but a lot of customers are complaining about that sound
      Ricoh europe should take action on this very fast!
      greetz
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        I've had some hot roller bearings get noisy on some also. I really hate this fuser design.
        • salgua6869
          FUSER NOISE
          Originally posted by largo
          customers complaining from noise from fusing
          Greetz
          replace oil supply and cleaner rollers
          • salgua6869
            Replace oil supply and cleaner rollers
            • largo
              • 30
              It's a clicking noise every time
              like Cipher describes: Idling fuser
              greetz
              • Ltd
                • 90
                Apply grease
                Aplly white high temperature grease ( from Ricoh ) to pressure roller flanges then reinsert bearings, the clicks will go away.
                • labish
                  • 21
                  The noise is very laud on the machine with the bearing in direct contact with the heat roller no bushings install and for this problem Sharp found a magic solution something like 5 bucks high temperature Teflon spray and looking at my garage door W40 do the same magic. Unfortunately after a weekend the sound of a flat roller is an addition to the tac-tac that drives people crazy. I replaced the bearings and the used one you can hear the balls inside touching the frame. These bearings I can tell are not high temperature bearings.
                  • stephend
                    Senior Technician
                    • 306
                    Hi Labish,
                    you are Ricoh tech??
                    any roots in SE of Europe?
                    • labish
                      • 21
                      Hi Stephend yes I was but not anymore Thanx God. You're the lucky one to fix this "creation" of Ricoh and about these bearings maybe came from Calgary made in Foothills area!!!
                      • stephend
                        Senior Technician
                        • 306
                        Yes...you are right. Pure made in Foothills. Hope you was able to rich the financial success for an early retirement
