228c bypass goes reverse?
+ More Options
Posts
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Hi guys, i have one of these machines whereas the paper in the bypass gets kicked out (straight away) any of you had this trouble? any ideas of a fix?
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • Canadian Tech
    Too Long in this field
    • 32
    Assuming you mean a 2228C (or 2238C) I beleieve If you replace, the feed roll you find the problem is gone, as there is a one-way needle bearing that can bind up. It's a good idea to replace the rollers as a set.
    Most of the time the operators need fixing, not the machine !!!
    • Jomama46
      • 2900
      Yep, it means the sep roller is winning the battle. Replace as a set.
      sigpic
      A+; Network +; PDI+
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        When this happens, I like to tell the customer they really broke it this time.
