MP 301 / MP 1013
  • woko
    • Jun 2017
    • 44
    [Electrical] MP 301 / MP 1013
    Hello fellow Tech guys, I am waiting for a heater lamp (fuser) for a customer with a MP 301, I was wondering if any one has used a lamp from a 1013, they look the same size and there is on one number difference in the parts book, The customer is jumping up and down and this will end up being my fault.
    Regards Woko
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MP 301 / MP 1013
    If it fits and it's the same wattage and voltage I don't see any reason why you can't use it.
    Hit it.
    • 8T2
      • Aug 2015
      • 257
      Chances are it's probably a lower wattage lamp so it may code out on startup or during a run bit it's worth a shot in a pinch. Let us know if it works
      Sent from my WAS-LX1 using Tapatalk
      • KeviM
        • Oct 2019
        • 327
        Like the other tech said, if it fits, has the same wattage and voltage it might work. MIGHT
        That being said the equipment has evolved alot since the 1013 not to mention the toner has evolved as well.
        Give a try... With caution ⚠.
        Also be very careful I once fused a hot roller and pressure roller by using the wrong thermistor on a 1013
          • 37628
          Probably not. Lower wattage which could lead to error codes due to longer warmup time. Heat distribution across the length might be different.
          • Ricoh-ono
            • 340
            Wattage is different. Here is the lamp description from each parts catalog.
            1013
            Heater - 120V/800W
            MP301
            HEATER:120V:850W: INFRARED
            Do what you can, with what you have, where you are. ~Theodore Roosevelt
