Ricoh MPC4503 scan problem
  • COPIERMAN
    • Jun 2009
    • 559
    have a customer have a windows server 2011 and scan to folder not a problem. now they have a windows server 2016 that wont scan to folder and copier has latest firmware. They call ricoh said will not work with that software. Just wanted to verify that is true.
    Thanks in advance
  • anothertech
    • 1769
    Re: Ricoh MPC4503 scan problem
    It should work, are you sure about the firmware versions?
      • 37488
      In order for SMB scan to folder to work with Server 2016 or later certain network settings on the C4503 must be correct.
      1. Domain name must be correct
      2. The first DNS must be the local domain DNS, usually the domain server itself
      3. Destination must be by computer name not IP address.
      • COPIERMAN
        • Jun 2009
        • 559
        firmware that I have
        D1495561S web support
        D1495567Y network
        D1495560T scanner
        D1495569R system / copy
        D1505519N op panel
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Thanks in advance
          Of course it can scan to 2016 ricoh would not say that.
          Probably firmware or a firewall
          Regards Mark
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            D1495567Y network
            D1495560T scanner
            D1505519N op panel
            You best to update with package firmware
            Also your firmware is well out of date
            Regards Mark
              • 37488
              Is there some specific software that they are trying to use like maybe scan router? Scan Router is not compatible with current Windows server versions.
              • COPIERMAN
                • Jun 2009
                • 559
                They were using window server 2011 everything fine then upgraded to 2016. When they had problems continue to use old server but wanting now to do it using 2016.
                  • 37488
                  If they are using Scan Router, a software that Ricoh used to sell, they may need to upgrade to v2.60 to gain compatibility with Windows 10 64 bit. The 2 websites that I have found that were not blocked by my anti virus software do not show any compatibility any Windows server after 2012.
                  Router Scan V2.60 - sgfasr
                  Router Scan v2.60 | blankhack
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    you need to initialize the folder path again in the address book together with the log in
                    AND
                    the scanner ip address needs to be defined in the firewall and mail server as safe.
                    • Zaxxon
                      • 608
                      Perhaps try this tool fro Ricoh.
                      Scan to Folder Configuration Tool Downloads | Ricoh Global
                      Please start you post with brand, model, problem.
