Pink toner hue on all but black print
  • WIZARDofJOZ
    • Feb 2013
    • 28
    I have a Pro C5100s. All of the color sheets have a magenta toner on them. The black by itself does not.
    I will add pictures so you can see.
    is it is a Transfer belt issue or what?
    • 36749
    It is a problem with either the Magenta PCDU or the HVPS for the Magenta charge roller. The magenta on the ends of the transfer roller is because the entire width of the magenta drum is getting toner applied to it.
    • WIZARDofJOZ
      • Feb 2013
      • 28
      I did put a new charge roller, Wax bar and blade. Vacuumed everything out really well. I am not sure why it would go from a slight hue to this much toner
      • Ricoh-ono
        • 339
        Try replacing the magenta drum potential sensor.
        Do what you can, with what you have, where you are. ~Theodore Roosevelt
        • WIZARDofJOZ
          • Feb 2013
          • 28
          wouldn.t that throw a code....no code on machine
          • TonerMunkeh
            Professional Moron
            • 3865
            Not necessarily, I'd try a drum first.
            Hit it.
            • Leoculus
              • Jul 2024
              • 62
              could try swapping the sensor for a different colour to see if the issue follows the sensor if you dont have one and want to confirm before ordering one
              • WIZARDofJOZ
                • Feb 2013
                • 28
                Replaced entire drum Unit (PCDU) After printing about 50 pages there micro tiny random dots of magenta over the whole the sheet. the sheet looks slightly tinted
                Could it be the Transfer Belt cleaning unit??
                • JonManchester
                  Technician / Shop Manager
                  • Aug 2013
                  • 103
                  The cleaning unit wouldn't just have magenta allowed on pages, you would have multiple colors and issues. It could be the itb transfer roller for the magenta unit. It's definitely related to the magenta PCDU or itb transfer.
                  Live for something or die for nothing.
