Pro8200
  • toddanderson
    • Dec 2005
    • 236
    Pro8200
    I have Pro8200 that comes up ready just fine, warms up cycle and ready to copy when I hit the print button
    the display say's (Printing ) and nothing happens, the machine just says printing. no paper is pulled or no c-codes .i checked the fuser and it does warmup and cycle but if I send a print job or copy nothing happens it just says Printing
    thanks for any help
  • mikadonovan
    • May 2008
    • 2931
    Re: Pro8200
    I've not worked on this model, but on other models that have had that fault it's normally been the HDD.
    NEVER ASSUME ANYTHING
    • gilbert
      • Oct 2017
      • 38
      Re: Pro8200
      Hai
      I have worked on that device a number of times.
      At least one or two below should resolve your issue
      1. Check/replace the hard drive.
      2. update all the firmware for the device.
      3 Replace the controller board
      • toddanderson
        • Dec 2005
        • 236
        Re: Pro8200
        Thanks for your help
        Hard drive did resolve the issue
        Originally posted by gilbert
        Hai
        • csliao
          • Oct 2021
          • 33
          Re: Pro8200
          [QUOTE=toddanderson;1898768]我有Pro8200,它可以很好地啟動,早期並準備好複印,當我按下打印按鈕時
          ,記錄顯示(正在打印),但沒有反應任何,機器只是說沒有拉紙或沒有c 代碼。我檢查了定影器,它會加速和循環,但如果我發送打印作業或複印什麼打印也沒有發生,它只 是打印
          感謝任何幫助/QUOTE]
          它是正常一直是硬盤。
          或者你可以try,進入服務模式,
          (SP 5832),HDD format 它通常是硬盤
          • anothertech
            • 1769
            Re: Pro8200
            [QUOTE=csliao;1927659]
            感謝任何幫助/QUOTE]
            它是正常一直是硬盤。
            或者你可以try,進入服務模式,
            Yeah, because we all read Chinese here on this English language forum.
            • elmaligno
              Expert technician KM
              • Oct 2009
              • 302
              Re: Pro8200
              If you are using the postcript driver and the SD card for that language is missing or removed from the controller, it does what you are saying.
              Field technician since 1994
