SP 4510SF, Cannot print from USB
  • es_ingress
    • Sep 2021
    • 4
    Hi all,
    Purchased a used Ricoh SP 4510SF, all functions seems ok except no printing from USB / SD.
    Nothing happens when pen drive / SD Card inserted in front panel.
    Web image Monitor > System >
    Media Slot Use > Print from Memory Storage Device
    already set "Allow"
    But it can scan and store to
    Memory Storage Device. So it seems both slot are fine.
    Performed all memory cleared, but it still cannot Print from Memory Storage Device
    Thanks in advance for any help, suggestions.
  • davel
    • Oct 2011
    • 1108
      • 37628
      Re: SP 4510SF, Cannot print from USB
      When you go to the print function screen does the "Prt From Dev" appear to the right of the Print Jobs tab?
      • es_ingress
        • Sep 2021
        • 4
        No. Thanks!
        • es_ingress
          • Sep 2021
          • 4
          Oh. Where can i input the values? and where can I found the birth certificate? in SP mode?
          Thanks!
            • 37628
            Originally posted by es_ingress
            No. Thanks!
            Then recheck that Print from Memory Storage Device setting. I have a feeling it is not enabled. That is the only setting in the Security Guide.
            • es_ingress
              • Sep 2021
              • 4
              Web image Monitor > System > Media Slot Use > Print from Memory Storage Device > Allow
              And setting from panel.
              Any other place I need to check? Thanks!
              • enricos
                • Mar 2019
                • 19
                As far as I can remember these kind of copier uses USB only for scanning inside of it, printing a file from it is not possible
                • Debs1964
                  • Oct 2010
                  • 1693
                  I may be wrong, but I think you need the optional HDD to print from external memory storage device
                  There are 10 types of people in this world, those who understand binary maths and those who don't
                  • GIUBOSS
                    • 1437
                    It can
                    print directly from USB stick or from
                    SD card, my friend
                    • Debs1964
                      • Oct 2010
                      • 1693
                      I just checked, if you don't have the optional HDD then you will not get this function
                      • sandmanmac
                        • 3990
                        This is a fact.
                        (Welcome back, Debs )
                        Edit, I didn't see your follow up post confirming this until after I posted mine
                        • Debs1964
                          • Oct 2010
                          • 1693
                          Originally posted by sandmanmac
                          This is a fact.
                          Thank you
