MP 4054 Allocation Buttons
  • laser801
    • May 2014
    • 151
    Hello Folks! Got one I haven't seen before... Setting up a MP4054, and going to "user Tools", "System settings", Trying to set up all the buttons for Copy, Fax , Print, Scan, on the control board... Usually there is a "Function Allocation Tab there. There is NOT! I have never seen this and have set up many of these machines... Is there another way to get these buttons programmed so they just don't Beep ??? Or how can I get that Allocation Tab to show up???? HELP ! I do appreciate your feedback always !
  • GIUBOSS
    • 1437
    Re: MP 4054 Allocation Buttons
    Configuring function keys (when using the standard operation panel)
    so have you already done this procedure?
    • laser801
      • May 2014
      • 151
      Originally posted by GIUBOSS
      Yes .. I tried 1st thing...User Tools, System Settings, and its usually right there..."Function Allocation" No sign of this tab... Never saw this...
      • mikadonovan
        • May 2008
        • 2931
        The last time I had a problem like this I had to update the op panel firmware(LCDC).
        NEVER ASSUME ANYTHING
        • laser801
          • May 2014
          • 151
          Thanks! That's the 1st thing I did...Nothing...
          • GIUBOSS
            • 1437
            Did you reset the machine from WIM?
              • 37566
              Have you tried using the SOP designer tool?
              • DRichard
                • May 2008
                • 482
                Doesn't he have a standard Op Panel?
                "Enjoy every sandwich."
                -- Warren Zevon
