plock pbm-350e
  • jujitsu47
    COPIER TECH SPECIALIST
    • Jun 2014
    • 20
    plock pbm-350e
    arrived to a Bk-153 in B2. i ck'd all connections on the back and all it did was give me other errors when i turned it on with out tirimmer or stacker. bk-151, bk-015, bk-001 .
    this is a new unit and all of a sudden it is having this issue after a month. pls advise if you can help
    • 37488
    Not familiar with the newer Plockmatic but with the older BK 5030 and BK 5010 there was a terminator jumper(s) that went on the last downstream device in the chain. If you removed the trimmer/stacker you had to move the jumper(s) back to the main unit of the booklet maker.
    • jujitsu47
      • Jun 2014
      • 20
      yes this style also uses the jumper. its just throwing up these errors random. going to switch the power and communication cords and see if it makes a difference.
      • jujitsu47
        • Jun 2014
        • 20
        TR-M2 FIXED ALL ISSUES....
