Mpc 3004ex, dont recognize sd card from slot 2, despite controller replacement
    • 37048
    #16
    Re: Mpc 3004ex, dont recognize sd card from slot 2, despite controller replacement
    Originally posted by Brianneoe
    There is a setting in the System \Administrator\ that you can lock out firmware updates. Its a little tricky and hard to find if the setting for Administrator login is not active. Some vendors will turn on that setting, make the changes and then logout. You will not be able to view the change unless to turn back on the Admin login for the machine. A NV ram clear won't reset this setting but a replacement of the NV will.
    I have ran into similar with Custom network settings. If admin authentication is off you can't even see the setting.
