Jam (057) on MPC 3004 every time
  • JayPaul
    • Oct 2012
    • 305
    Hi all,
    I'll start from beginning, customer called me out maybe a year ago for making a noise and jamming. Got there changed some feed tyres, checked around for what could be making noise didn't find anything, machine started working fine.
    6 months ago they log a call for same thing, I spend about an hour checking over parts, looking for anything that could be causing it. It pulls the paper out of the tray, skews it somewhere between paper feed and transfer I believe, makes a kind of grinding noise and jams when it gets half way through the fuser. I fit new tray 1 and 2 feed motors, swapped whole feed unit. Problem went away but I still wasn't sure. Recently they called again saying same problem again. This time I just swapped the machine out so I could bring it back here to work on.
    I put it next to another MPC 3004. In total I swapped ITB, Fuser, Whole duplex door, Transfer assembly, Feed units, Feed motors and clutches I think. The problem still remains. Can't get a single page from any tray, always makes the awful noise, skews and jams half way through fuser. Jam code 057. Machine also had firmware update. Done 730k total so it's hardly a new one.
    At this point I've run out of things to swap, from where the paper starts, feeds upwards, is all new parts?! Anyone else had this or have an idea what else to swap next. Next thing on my list was paper exit/interchange unit, but considering it skews before it even gets to the fuser, it can't be that.
    Any new ideas will be appreciated
  • Gift
    • Mar 2011
    • 2459
    Re: Jam (057) on MPC 3004 every time
    Might be the combined fuser/paper exit drive assy, I think it contains a torque limiter and one way clutch gear that can become faulty. Also check if all junction gates are moving freely / aren't sticky. The fuser sleeve itself can also cause jam issues if it's not sliding smoothly over it's internal contact plate - usually it does work in A4/LTR SEF mode because there's more friction between sleeve and press roller.
    Skewing is also not good - check the reg roller bushings and the transport belts in the right doors / vertical transport - i'd probably check these things first before considering the fuser/drive stuff.
    Good luck^^
    • MIKON
      • Jul 2015
      • 191
      Check registration roller tension springs.
      • JayPaul
        • Oct 2012
        • 305
        Sorry to clarify, what I call transfer roller, is what you call registration roller. It's just an old habit of mine.
        From what I can see the junction gate above fuser is in correct place as when you run it SEF a tiny bit of it does poke out at the paper exit, meaning it is going the right way.
        But already has new fuser and the entire duplex door, containing all the little feed belts etc and registration assembly (the entire unit) and I know all these parts are ok because when I put them all back in the other 3004 it works fine. The fault never swaps between machines no matter how many parts I swap.
        • Gift
          • Mar 2011
          • 2459
          Well then I'd probably go for the fuser drive assy even if that won't explain the skewing.
          Once I had a weird noise from the transfer roller assy (the real one^^) - there's a discharge metal plate with tiny metal spikes in a row - one was bent up.
          • JayPaul
            • Oct 2012
            • 305
            Yeh I know the ones you mean, makes a kind of scratching sound, have to press them back down with small flat blade sometimes.
            Ok so now I have swapped out fuser feed, whole paper exit unit, fusing motor, paper exit/pressure release motor, paper transfer contact and release motor and still has the exact same problem.
            I think this is the most parts I have ever swapped out between 2 machines before and still seen no change. The only thing from here is pulling out every single object that turns in the back of the machine during paper feed process... not quite a job for 4pm on a Friday though...
            Also worth mentioning as I forgot earlier, have run every OUTPUT mode on it and none of them replicate the awful grinding noise it makes, they all run fine
              • 37628
              J057 is a registration sensor LAG jam. That means that timing of the trail edge at the sensor is not correct. It could be the sensor, the registration clutch or the wrong paper size.
              • FrohnB
                • Jul 2017
                • 1919
                +1 on the Registration clutch/ motor.
                Omertà
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  That happens on the older machines designed changed on 03 series.
                  Regards Mark
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Originally posted by JayPaul
                    Hi all,
                    Could it have anything to do with the ptr assy or transfer assy locking up bearing come out of place
                    Regards Mark
                    • tsbservice
                      Field tech
                      • 8064
                      I will try to manually move a sheet of paper through registration rollers to check for uneven pressure. Also skew may be when paper hits/catch something. Can you crash stop A3 paper halfway through registration?
                      • Gift
                        • Mar 2011
                        • 2459
                        Did you swapped just the motors or the entire assy?
                        • JayPaul
                          • Oct 2012
                          • 305
                          So somehow I didn't replace the registration clutch/motor when I changed the feed ones earlier months ago. Changed it and all problems went away, put it back in and problem returned instantly. SO swapping that out did fix it. Seems so simple the way Slimslob wrote it but do I often find the jam codes can point towards one thing solely but it is something else that causes the inital problem.
                          Nice one for the info
