MPC3504ex TouchScreen issue
  • Popolopo
    • May 2023
    • 151
    [Misc] MPC3504ex TouchScreen issue
    If the touch screen have be calibrate wrongly and current when press at it, it will click on the other press(not on the finger). Is there a way to reset it?
    I can't to go service mode, as cant press the check status. If able to, I not sure whether can press the sequence to go for calibration again.
  • Gift
    • Mar 2011
    • 2456
    Not shure if you can calibrate such a huge offset due to an error during the process - perhaps the touch panel is just faulty and the offset got more worse (since somebody intitally tried a calibration before). If this is a contract machine I'd probably get my hands on a panel from a donator machine or order the digitizer.
    • Popolopo
      • May 2023
      • 151
      It was slightly offset before. But after wrongly calibrate, if I press "stop", it will go to menu button there.
      If not mistaken, there are recovery mode like android. But I unable to go to that mode. Not sure the key combine is right or not. 1 and 3 hold then power on, after that 1 and 2 hold. Is that right?
      • Leoculus
        • Jul 2024
        • 62
        plug a mouse into the usb slot on the touch panel and try calibrating with the mouse
        • sandmanmac
          • 3996
          x 2 on this
          • Popolopo
            • May 2023
            • 151
            Thank you. Finally, can calibrate it back.
            DIdn't know that can use mouse.
