MP7503 Will Stop During Job "Please Wait, Warming Up"
  • MitchD
    • Oct 2012
    • 164
    I have a MP 7503 in a school that has been stopping during print or copy jobs randomly throughout the day and saying "Please wait, Warming Up". After 5-10 min the machine will continue and finish the job. It does not log any SC codes either. I have updated the firmware, checked over the fuser, changed thermistors, and double checked all setting in user tools. I am at a loss here. Any suggestions?
    The machine has under 350K and otherwise is working great.
    "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
    • 37532
    Re: MP7503 Will Stop During Job "Please Wait, Warming Up"
    One if the 3 fusing lamps might be bad or disconnected.
    • tsbservice
      Field tech
      • 8020
      Absolutely. I had it on other brand and this was due to either - bad fuser lamp, bad/corrupted HDD, trying to add toner wrongly judged. .
      • KeviM
        • Oct 2019
        • 324
        Agreed with Slimslob. Take fuser unit out and check lamps. Also check thermistors and upper fuser roller/hot roller.
        Also as the other Tech said, might be hard drive. Update firmware, check controller and hard drive.
        • mgipa
          • May 2020
          • 49
          • j2shortt
            Learning to speak PCL...
            • Feb 2019
            • 56
            thermistors maybe not making full contact with hot roller??? or they could be covered in built up toner...... impeding the transmission of heat to the thermistor.. just spit balling tbh
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Remember the 03 thermistors are different to all the others ie mp7500/1/2 also the hot roller would be due at 350k to be replaced
              Regards Mark
              • luca72
                • Oct 2017
                • 1784
                I would not like to go too far with the imagination, try to change the hdd, so much is a fast operation, otherwise I would opt for the psu or the card that powers the fuser lamps, whose high frequency transformer does not work properly (less power = more time )
                ....I do not know? maybe a cold solder on some psu-connector?
                "I'll be back"
