MP 4002 not sending but confirm says completed
  • digicor
    • Jul 2008
    • 1153
    I have a mp4002
    has connectivity, prints, pings smtp sever, but the email says sent, 100% and the log says completed, yet no email is being received ,
    machine has been pinged, and re started hard re boot, email being used is active and working, i tried three different isp's aol,gmail,and my web mail at my dot com witch is working
    believe me .. lol...
    is there an internal Pctler issue that would cause this?
    customers email is working, from the same building, same office, same router.
    any suggestions will be appreciated.
    • 37458
    Re: MP 4002 not sending but confirm says completed
    Unless the scanned size of the PDF is larger than what the email provider allows, most likely the problem is at the email provider not the 4002.Try using Wireshark to monitor the transmission.
    • KeviM
      • Oct 2019
      • 324
      Yes. Excellent suggestion by Slimslob.
      I would like to add, these are some of the things I try in that situation
      1) change max email size. I either put it off or reduce the size.
      2) I put divide and send email off.
      3) Since the machine is saying that the email is sent , in my experiences the machine has sent the email to the server at this point your machine receives a confirmation that it is received but from there it can be blocked by the email service provider. The customer needs to contact the email service provider and tell them that emails are being blocked and from what email address. I've had this issue before.
      I've had all of these issues before.
      Hope this helps
      • Brianneoe
        • May 2015
        • 318
        Change the senders name. I run into this a lot and I will have the customer change it to a gmail account or my .me account name for testing purposes. Always works. AOL and YAHOO accounts seems to be the most problematic.
        • digicor
          • Jul 2008
          • 1153
          This was the problem, the senders accnt was AOL, worked for years, now it does not, i changed the sender to a gmail, unt vhalla its working,
          remember when any email worked with any thing? and there wasnt any ssl or security on email? yep the world is a safer place with the internet.... NOT / LOL
          just use the fax maam just the fax....hahaha
          Telex anyone? im old....... hahahah
          my younger clients ask " whats a land line?" lol
          thanks fellas for the help
            • 37458
            I remember now that a number of years ago a few of the free online email services made a change that required the domain of the authentication name and the sender name had to be the same. I can't remember if Ricoh put out as bulletin on it or if tech support told me but there is a setting in SP that would force the authentication name to be used as the sender name during negotiation and then put the actual sender in the body of the email. Gmail was one of those services.
              • 37458
              TTY is still available for use by the hearing and speech impared.
