IM430f Toner not set correctly
  • COPIERMAN
    • Jun 2009
    • 561
    I went out yesterday they already try two different toner cartridge both said same thing. everything looks fine. I try pushing in on toner and drum cartridge and it would make connection. then i wedge paper on both sides of drum carriage and it work for now. I was wondering if there is a bulletin on the toner connector chip #D0A42499 to fix problem or do i need to just pull metal tabs and farther. Thanks in advance
  • Oze
    Ricoh Fanboy
    • 1663
    Re: IM430f Toner not set correctly
    You're welcome
    RD0AP007.pdf
    RD0AP013.pdf
    • COPIERMAN
      • Jun 2009
      • 561
      thank you again for information
