C6004
  • Tonerkiller
    • Oct 2012
    • 668
    C6004
    I do not see where to the login button is. Is there a secrete to finding where to login to this machine.
    • 37489
    Login to what? If User Authentication has not been enabled then there will not be a login needed for Copy, Fax and Scan.
    • Tonerkiller
      • Oct 2012
      • 668
      Login to wipe the harddrive, to send it back to the leasing company.
        • 37489
        What screen on the SOP are you trying to use?
        • copier tech
          • 8144
          Enter service mode then use SP5-832-001 (HDD Formatting (ALL) to format the HDD.
          How to Access Service Mode Ricoh MPC6004, Print PM List, reset SC541 SC542 Fuser Error, Quality Test
            • 37489
            All that does is rebuild the indices. It does not erase the files,.
            • copier tech
              • 8144
              It will wipe the HDD which is what the OP was asking.
              • Gift
                • Mar 2011
                • 2459
                You need to enable admin authentification first then you'll see a log in button in user tools in order to use all functions including a proper data wipe + HDD overwrite.
                • Tonerkiller
                  • Oct 2012
                  • 668
                  You are the BEST!!! That is the piece of the puzzle that i was missing.
                  Thank you
