Ricoh mpc 2011 slow printing
  • gilbert
    • Oct 2017
    • 38
    [Misc] Ricoh mpc 2011 slow printing
    Hi Techs
    I have a Ricoh mpc 2011 which is taking long to
    print when a print job is sent. I have other printer brands in
    the same segment which are working fine.
    Please assist me resolve this issue.
    thank you.
  • nokktekk
    • Mar 2018
    • 44
    Re: Ricoh mpc 2011 slow printing
    Which printer driver are you using? Is it printing slowly from all applications?
    • emiliorsg
      • Jul 2018
      • 141
      Download the driver from the ricoh support page and install it. it will surely be using the windows driver.
      MP C2011SP Downloads | Ricoh Global
      • 8T2
        • Aug 2015
        • 257
        Is it printing via IP or WSD port?...if WSD switch to IP
        Sent from my WAS-LX1 using Tapatalk
        • gilbert
          • Oct 2017
          • 38
          PCL 6, yes all applications
          • TonerMunkeh
            Professional Moron
            • 3865
            The lower speed 03's have always been catastrophically slow printing. Try switching Java off if it's not being used.
            Hit it.
            • Gift
              • Mar 2011
              • 2459
              +1 for WSD or perhaps a crappy wlan connection in case there's a wireless network
              • gilbert
                • Oct 2017
                • 38
                its via IP
                • Gift
                  • Mar 2011
                  • 2459
                  Originally posted by gilbert
                  its via IP
                  did you really check the port at the customers driver setting? If yes, try a quicky test with your laptop + direct lan connection to rule out the MFP or customer it.
                  • D_L_P
                    Self Employed
                    • Oct 2009
                    • 1196
                    Hi Techs
                    thank you.
                    Many times I would setup a workstation with a local printer instead of going through a print server share. The slow printing issues would be resolved. Flush the print queue at the server or use an KM undelete to remove the print driver and reinstall. Maybe try PCL5e?
                    It's rare but a HDD going bad can cause slow printing.
                    Also rare is a duplicate IP. Someone with a laptop or mobile device that isn't always on the network could have the same IP as the Ricoh.
                    • 8T2
                      • Aug 2015
                      • 257
                      its via IP
                      If WSD is not disabled on the device it automatically installs a new printer using the generic Ricoh Class driver which is notoriously slow and causes tons of headaches when user codes are implemented. But if it's slow via IP I'd first ping the device to check response times to determine if it's a network or not and take it from there
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Delete driver, put on dhcp for a new ip adress and install it all again.
                        Be sure you select the right driver for that pc's Windows platform.
                        Check the gateway ip.
                        Upgrade firmware.
                          • 37628
                          Do not let Windows automatically install the printer. After you click "Add Printer" a Window will open that says "Choose a device or printer to add" At the bottom of that window click "The printer that I want isn't listed" Select "Add a printer using IP address or host name" Follow the prompts.
                          • luca72
                            • Oct 2017
                            • 1792
                            Hi Techs
                            thank you.
                            it could be the dirty ip port, try to delete it, and recreate it, or change ip address, as you like...disable wsd in wim configuration, and install ricoh pcl6 driver on pc
                            "I'll be back"
