White Streaks When Printing Yellow
  • Heber302
    • Oct 2021
    • 16
    Hello Everyone,
    My yellow prints contain multiple white streaks (See attached images) . I printed 3 solid prints for all 4 colors. The magenta seems to print flawless, the black and cyan have very dim streaks along the long sides of the paper and the yellow is horrible as it has white streaks ( multiple ) along the sides of the paper. The thing I don't understand is that the streaks on black, cyan and yellow align perfectly. So if yellow was the problem I should not see the lines in cyan and black unless they do need a little yellow toner.
    I have added new developer for all colors and changed all the transfer rollers on the machine (they were due) hoping the problem was going to be resolved. However, the problem is still present. I bought a new fuser belt I need to replace today but I'm starting to think is not the fuser but instead the problem is the yellow PCU. Before buying a new PCU for yellow toner though I wanted to get your opinion on what could be causing the streaks to appear heavily on yellow and dim on other colors.
    I'm out of ideas here aside from changing the PCU but that is expensive so i'm trying to leave that as last resort.
    Any help will be greatly appreciated.
  • FrohnB
    • Jul 2017
    • 1919
    Re: White Streaks When Printing Yellow
    Clean yellow laser glass.
    If that doesn't help,
    Replace yellow development unit.
    Omertà
    • Heber302
      • Oct 2021
      • 16
      Hi FrohnB
      Thank you for the suggestion. I checked the laser glass and it was clean. I think I will go ahead and order the development unit. Do you know why I see the same streak but dimmer in cyan and black? I know the yellow is the main problem since the solid yellow print clearly has the white streaks all over. However, I don't understand why they also appear in a dim way for cyan and black as well.
      Let me know if you have any suggestions.
      • FrohnB
        • Jul 2017
        • 1919
        Originally posted by Heber302
        Hi FrohnB
        Can you post a photo of the Color Calibration page? That would be helpful.
        Omertà
        • Heber302
          • Oct 2021
          • 16
          Here is the test patter. The yellow is pretty bad.
          • jermyth
            Riso dude
            • Mar 2011
            • 441
            Looks like drum charge roller(s).
            • Heber302
              • Oct 2021
              • 16
              I changed all 4 charging roller 3 weeks ago and it print fine until recently. The charging roller looks pretty good with no scratches or anything that would cause a bad current. But I also suspected it to be the caused at first. I would much rather spend money on a charging roller than a development unit.
              The development unit has new developer, drum and charging roller the only thing left to replace is the actual development unit although per the counter is not time to replace.
              Do you think the fuser belt could cause the streaks? The streaks appear in thin and thick stock. I read the troubleshoot manual and it says it could be the fuser belt but I think the problem is coming from the development unit.
              thoughts?
              • Oze
                Ricoh Fanboy
                • 1663
                I can't believe that NOBODY has asked the obvious...what model machine?
                • davel
                  • Oct 2011
                  • 1108
                  Machine model?
                  PM counters?
                  OEM parts/consumables?
                  • Oze
                    Ricoh Fanboy
                    • 1663
                    Originally posted by davel
                    Machine model?
                    PM counters?
                    From his description I bet ALL the devs are over life and depending on the model the dev units aren't THAT expensive...cheaper than a PCDU.
                    • Heber302
                      • Oct 2021
                      • 16
                      Well I'm a moron. I can't believe I left the machine model out.
                      Machine: Ricoh 7100sx
                      Per the PM counter none of the parts are close to their end of life. My guess is that the yellow PCU is not working correctly. I triple checked all the consumables and found nothing wrong. The machine has new developer in every color and full OEM toner which have been working great until recently when yellow color issue began.
                      Any suggestions are greatly appreciated.
                      Thank you.
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        When you write "print" you don't mean accidentally copy?
                        • davel
                          • Oct 2011
                          • 1108
                          Look at the yellow dev roller, can you see any voids that correspond to your white streaks, double check nothing is in the laser beams path.
                          • imaginemoko
                            unTrusted Tech
                            • Jan 2008
                            • 289
                            I encounter before a new charge roller unit with like wax or powder on the roller, just wipe with damp cloth and water and another scenario was installed look like same charge unit but for different model.
                            fix the customer first then fix the machine... its simple and makes life more easy.
                            • luca72
                              • Oct 2017
                              • 1791
                              Hello Everyone,
                              come on, it's the doctor blade clogged, with your fingers, turn the gear of the development group back and forth, about twenty times, also give a few taps along its entire length, under the development group with the screwdriver handle between one turn and the other 'other, if it does not disappear completely> replace, you may notice this even from the pm
                              "I'll be back"
