Ricoh MP2553 / 2352 / 2851 Squeak
  • KeviM
    • Oct 2019
    • 324
    Hi guys, I trust everyone is well
    Got a bit of a problem. Was wondering if anyone has any solutions to this..
    In a few of my Ricoh MP 2553 , 2352, 2851 there's a squeaking. It is coming from the fuser unit bearings. I've replaced the bearings with brand new originals but the problem comes back after about 2 weeks. Besides that the machines work fine.
    Anyone got any solutions
    Thanks in advance
  • rthonpm
    • Aug 2007
    • 2859
    Re: Ricoh MP2553 / 2352 / 2851 Squeak
    What are you using to lubricate the bearings? Going all the way back to my days with the 5622/5627 series (AF 1022/1027) I've used Krytox and never heard a squeak out of a bearing.
    • sandmanmac
      • 3981
      Agreed.
      Seems that his answer is in the question.
      There's NO mention of grease, so I wonder if he's actually even greasing the Hot roller shaft or just popping them in dry
      • luca72
        • Oct 2017
        • 1784
        Thanks in advance
        the hot roller, did you change it, or just the bearings? ... the section may have shrunk at that point, if the roller its used, in conjunction with poor quality of the grease once it has dried...it could generate resonances, and therefore squeaks
        "I'll be back"
        • KeviM
          • Oct 2019
          • 324
          I've installed brand new original hot roller and bearings. Squeak returned after about 2 weeks.
          Prior to that it had a squeak and I sprayed some Q20 lubricant oil. It helps but very little
          • KeviM
            • Oct 2019
            • 324
            I didn't grease it as it was brand new
            • luca72
              • Oct 2017
              • 1784
              just when it is new you have to put some grease, between the roller, and the bearing, no type of oil should be used, if you want some advice, after years of research, I recommend this in the photo, you can also find it on amazon, and it costs very little, the tube is small, and does not clutter the tool case, moreover it has a range of temperatures much higher than necessary, I am finding myself very well, so visible, it looks like the original ricoh grease
              "I'll be back"
              • Gift
                • Mar 2011
                • 2459
                I think that lubricating the hot roller shaft does prevent annoying "knocking" sounds but no squeaking. In some cases the strippers or thermistors can cause weird noises. Also check the press roller + cleaning roller bushings.
                Also check the surrounding parts, exit rollers, idle rollers etc...
                @luca72
                Interesting product. We use something rediculously more expensive - it works very well but I thin it costs 10x more. Do you have any long time experiences with that liquimoly stuff?
                • luca72
                  • Oct 2017
                  • 1784
                  @luca72
                  i also think as you say, about the noise, but honestly the grease there, i always put it, so not putting it or putting oil, it might as well squeaking (?), the product i have been using for about a year, on various models , for example on the metis, I fix the problem of (tac-tac-tac) from the fuser very well, first I tested the copper grease, but honestly, I found it a bit critical in use, it gets very dirty, and if you goes on pants (tried) does not go away anymore.
                  this, the thing that struck me, and the texture, the color, looks just like the original ..... let me make a joke.... "light color, clean taste..it's Glen Grant!" .. LOL
                  "I'll be back"
                  • Gift
                    • Mar 2011
                    • 2459
                    Always nice if the "knock off" can compete with the expensive stuff so mille grazie
                    I also tried copper crease once and agree with you 100%, next thing was silicone grease wich was ok at first but drying out to soon.
                    • rthonpm
                      • Aug 2007
                      • 2859
                      Oil isn't going to help. You have high temperature metal bearings moving against a high temperature heat tube: in the right environment you're going to get a squeak. That oil is going to dry up in no time at all since it's really just glorified WD-40. You need a good high temperature grease: Krytox, Chemplex, or Barrierta.
                      Anytime you replace a heat tube or press roller you always want to grease all of the bearings. I've been doing that on every black and white Ricoh fuser from the old 15 ppm machines up to the 90+.
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Almost any turning part can squeak.
                        Is it constant from the moment you press the start key untill main motor stops, or is there a (little) interval in the squeak?
                        Sp mode, output check, and narrow down the problem.
                        PCDU's can also squeak.
                        Et cetera, et cetera,...
                        • sandmanmac
                          • 3981
                          This thread is a great example of why it is so important to RTFM.
                          Service is A LOT more than taking stuff apart and putting it back together
                          Hot roller.pdf
                          • KeviM
                            • Oct 2019
                            • 324
                            [ATTACH=CONFIG]50617[/ATTACH]
                            Thank you. That's exactly what I needed to find out. Getting the right grease is a big problem here in South Africa. Now I have an idea on what to source out.
                              • 37529
                              Another good high temperature grease is Super Lube. You can often find it at local hardware stores or order online from Amazon. If buying locally make sure it says PTFE on the label.
                              Super Lube 92003 Silicone Lubricating Grease with PTFE, 3 oz Tube, Translucent White: Amazon.com: Industrial & Scientific
