Ricoh mpc 3502 panel language
  • Amr Mousa
    • Nov 2021
    • 1
    My Ricoh mpc3502 panel language is German only. i search on administrator tools and I can't find anything about language.
    How I can register or add additional languages like English or Italian?
  • copier tech
    • 8121
    Re: Ricoh mpc 3502 panel language
    We can supply you with the language files you require.
    Please contact us at www.printerfirmware.co.uk
      • 37052
      Normally there are 2 languages installed on a C3502. The are selected by a button in the upper right of User Tools I believe. If for some reason you only have 1 language installed, you need to do a firmware update of language1 and language2. There is only one language firmware. It contains all available languages. As part of the firmware load you have to select the two languages you want available to choose from.
