PROC5100S lines on prints
  • Keegan Chetty
    • May 2015
    • 113
    Hi everyone,
    Please could I have some assistance,
    I have 2 PROC5100 machines and one is down at the moment but I constantly have an issue with the other with these lines coming across the page, it only happens when using 80gsm paper, so normally I use this machine to print on 250gsm where I have no issues and I use the one that is currently down to print 80gsm, so because of the circumstances I need to try and get the 250gsm machine to print on 80gsm without the lines (I hope this makes sense).
    So I've replaced the following parts, C,M,Y,K PCDU's, transfer belt, I've taken these parts from the machine that prints perfectly on the 80gsm paper, the fuser belt, pressure roller and transfer roller is new. When these lines come up you can see it on the transfer roller that is why I replaced that first. I also tried picking the weight up to 81-106gsm but that doesn't seem to make a difference, the lines are sometimes cyan, magenta, yellow or black and are very intermittent, sometimes after 20 copies duplex, one page will have the lines and sometimes it could be after 100 pages duplex. It also happens on simplex, attached is a picture of what it looks like. Thank you for your assistance.
    • 37628
    Re: PROC5100S lines on prints
    In the future try putting a magic marker arrow pointing to each line. Also please indicate what the direction on movement of the paper.
    So I can only assume, and we all know what that can do, that you are referring to the two faint lines between the 2 sets of magic marker lines and that those lines are parallel to the paper movement. They could be fusing unit stripper lines. I would venture a guess that the fusing unit is due a PM rebuild and you did not swap fusing units with the other machine because it is why the other machine is down.
    • Keegan Chetty
      • May 2015
      • 113
      HI Slim, the pm on the fuser has recently been done, plus the lines were coming before the pm as well, I don't think it's the pawls as the paper is being fed in long edge and the lines are going down the page (sorry for not mentioning that part)
        • 37628
        If the lines are evenly spaced down the page, measure the distance between them. That will be the diameter of what ever roller is causing the lines.
        • tsbservice
          Field tech
          • 8064
          From his description it doesn't look like that slim. Seems it's related to faster processing speed when doing 80gsm.
          TS what will happen if you set machine for 250gsm paper but use 80gsm instead will it make those lines? Did you mean lines are visible on transfer belt when you say transfer roller?!
          • Keegan Chetty
            • May 2015
            • 113
            The diameter is the same as the paper transfer roller, but I've put in a brand new unit and also replaced the power supply for that roller
            • Keegan Chetty
              • May 2015
              • 113
              I haven't tried running 80gsm paper and setting the machine on 250gsm, I did try 106gsm but that doesn't make a difference. The lines are shown on the paper transfer roller, this is still after I replaced the entire paper transfer unit which was brand new, and the entire transfer belt unit with all 4 pcdu's from the working machine that ran the 80gsm perfectly
                • 37628
                It could be the PTR. I would think that if he sets it for 250gsm it might actually make the problem worse as the transfer current will be higher. Lowering the target transfer current for the 80gsm paper might work better.
                • Keegan Chetty
                  • May 2015
                  • 113
                  I will try with a lower current tomorrow and let you know the outcome, thanks Slim
                  • tsbservice
                    Field tech
                    • 8064
                    If circumference is equal to PTR diameter it sounds reasonable to try different settings, agree.
                    • copier tech
                      • 8220
                      Hi everyone,
                      Measure the distance between the lines then refer to the troubleshooting section of the service manual.
                      • Keegan Chetty
                        • May 2015
                        • 113
                        Hi Guys
                        update: tried paper weight 1 which is the lowest, still coming up with the lines, I can see the lines on the paper transfer roller but I don't know where it's coming from because the transfer belt unit including cleaning unit was replaced from a perfectly working machine and the paper transfer roller unit including the roller is doing 2k copies. Bear in mind this was happening before these parts were replaced as well. Tried removing the guide that sits under the transfer belt as well but still no luck..
                        • Keegan Chetty
                          • May 2015
                          • 113
                          This doesn't do much good as I know it's coming from the transfer roller, just can't find the cause, the manual just tells you which roller it's coming from.
                          • Pixtech Frameworks
                            • May 2020
                            • 241
                            Hi everyone,
                            Check cleaning blade of the particular color strips line that's showing. I've had same for a customer, cleaning blade was replaced and everything was fine. Give it a try
